help needed quick
  • help needed quick
    hi
    for a long time now been waiting to take the boat out, plan to go out tomorrow, i had to do a small repair on the light board ( dog chewed though it ) so done that " correctly " plugged it into the back socket and nothing worked apart from the right idicator " it came on flashing also a bleeping from back of truck " any help appreciated. im running out of time
    ark
    Only make right turns?
    Bulbs ok?
    Wiring correct?
    Eat.Sleep.Surf.Repeat.
      re
      Bulbs ok?
      Wiring correct?
      only if i could i would, far to many left turns
      will check asap, didnt have alot of time to check anything, just thought i would get some answers to try first.
        Indicators do flash and the beep beep is normal.
        Do your hazards work? No other lights at all on the board? What one thing connects all the lights...?
        www.johnthebuilder.info
          yes only the right side indicator was flashing when selected and also got the bleep from the rear of truck, No other lights were working at all. did try the hazard switch and again right light came on with bleep
            re light board
            im off out to bring board inside to check bulbs and wiring at light board side of things
            brb
              All the light board cant be fooked. xheck your eearth
                sorted
                got board in, cleaned down all connections inside light units, checked bulbs and now working a lot better all works apart from tail lights, i can live with that.
                  can the bloke who runs into you though?
                    Depends on time of day.
                    well, that was a bad idea!
