I know this has probably been posted before, however I can't find exactly what i'm after. The teeth on my mechanism have been worn out over the years and the window has been sticking/ slipping over the past year or so. It was usually the motor at fault, I have taken apart and repaired it numerous times now. It has finally given up the ghost due to excessive play on the shaft.
So.. I have bought a new motor, however the teeth look pretty rough on the mechanism. I thought best to change that out at the same time to prevent the new motor getting stuffed as well. My question is, how easy/pain in the arse is it to get the mechanism off the glass and out of the tailgate without trashing something else whilst doing so.
and do I need to set up the new mechanism in a certain way, i.e spring tension etc before fitting the new one. Are there any pics/ photos anywhere on the forum?
I have stuck the new motor in for now and the window is going up and down ok, a bit rough and juddering due to the teeth being a bit ropey. should I just live with that and stick my new mech on fleebay or go for the full refit??
