Has anyone tried to upgrade Gen 2 headlights using a Xenon type kit, is it even possible?
Xenon Upgrade
I made up a loom using 2.5mm multi strand cable.Originally posted by Surfboy View PostCan you do an upgrade with a simple run of replacement cable? If so, what gauge and from where to where? Or do you need a custom loom? Is it applicable to the 3rd gen?
I used the original drivers side headlamp connector as the trigger point to switch the new relays.
I replaced the original connectors.
My shopping list was
2 40 Amp 12v relays
2 fuse holder
2 headlamp connectors
2.5 mm cable and spiral wrap
It took a couple of hours to do but the results are amazing, I still laugh every time I flick on high beam it is that good.
I will post some pics up later if needed, but I am sure this has been covered?Last edited by shokenore; 10 March 2013, 12:33.Eat.Sleep.Surf.Repeat.
Thanks, I found
http://www.go.jeep-xj.info/HowtoHeadlightLoom.htm
Nice write up, I'm sure it would be the same for a Surf
You can buy kits from here or just follow the schematics and make your own.....
http://www.4crawler.com/4x4/CheapTri...adlights.shtml
