Originally posted by shokenore
View Post
Starting issues
Put your immobiliser fob on a bit of cord, then you won't have to keep taking the keys out!
Most immobilers don't reset that quick, you should get a couple of goes at starting it.
Batteries don't sound overly charged, but hard to tell.4x4toys.co.uk - Keeping you on and off the road...
Originally posted by TonyN View PostPut your immobiliser fob on a bit of cord, then you won't have to keep taking the keys out!
Think this is gonna have to be a garage job I don't wanna start buying starters or whatever and it turns out not to be the problem :-(Yes it's a V8, don't you know I'm loco?
Did the AA disconnect one of the batteries when testing them?
You'll only get an average of both if not, and can hide a duff one.
Dosn't sound like you're average starter motor issue, they either just click when the contacts go, just spin fastwithout turning engine if the bendix is stuck, or turn slowly or not at all if the motor is stuffed.
The immobiliser isn't normally hard to disconnect, it's normally pretty obvious which ignition wires have been cut when you look behind the dash.4x4toys.co.uk - Keeping you on and off the road...
Originally posted by TonyN View PostDid the AA disconnect one of the batteries when testing them?
ill disconnect them tomorrow and test them myselfYes it's a V8, don't you know I'm loco?
Originally posted by AlexKzn130 View Postno he tested each one in the car i think i recall after the engine running for about a minute each one showed about 13v
Nev.
Right then, so now we have eliminated the cold or hot start question.The starting issue is random? Yes ?
When the RAC got it to work did they jump start it?
If they jump started it and it turned over did it start ok?
If you have a battery charger, could you leave it on a trickle charge over night and see how it starts the next morning?
Have you checked the battery terminals are nice and clean and not loose and corroded?
Same for the alternator belts are they correctly tensioned?Eat.Sleep.Surf.Repeat.
Originally posted by shokenore View PostRight then, so now we have eliminated the cold or hot start question.The starting issue is random? Yes ?
AA never fixed it, I call them and they took best part of an hour to arrive so I had a coffee in the cafe over the road when they arrived to inspect the problem car started first time and made me look like a fool, the aa guy tested the batts out of good will I'm gonna test my batts today and check all the connections, I'll update accordinglyYes it's a V8, don't you know I'm loco?
Having similar issues with my truck (ln130) went to start it tonight, but slow and dead turnover without firing up. I'll admit it was stood for about two weeks, but even with a boost off my car still no joy. Think I've got the same immobiliser as you, small fob with 3 points on it.Hold my beer and watch this
Same for the alternator belts are they correctly tensioned?Yes it's a V8, don't you know I'm loco?
