I have looked around this forum and other sites and have found most of the information required to install my alarm. I do have a couple of queries on some of the connections and locations.
I have a few technical wiring diagrams but not having too much experience, they are more confusing than helpful!
Negative handbrake - best wire location?
Left and right indicators - 2 green wires at steering column?
Ignition positive when engine on. They suggest the tach line, oil light, or charging battery line. Which is the easiest to get to and what colours?
+12v when ignition on and cranking, 0v when ignition off. Black/yellow at ignition harness or red at ignition harness?
Starter motor solenoid or fuel pump relay, positive side - locations and colours?
Man these alarms have a lot of wires!
