My rear heated window demister doesn't work, following some research on here I found the female spade connectors had probably fallen off.
I took the rear tailgate apart and extended the glass and to my joy the male spade ends were disconnected.
I scrabbled around for the wires....... and to my horror they had been cut and taped up!!!! FFS!
I put my multi metre on the bare wires and got the missus to push the switch, but no current.
The light comes on, on the switch on the dash.
I cannot find any threads that suggest an earthing or shorting problem, so I am unsure why the spade ends would ever need cutting off..... any ideas?
