Hi can anyone explain the order or post a pic of the alternator adjustment bolt please, I removed the alternator but could not see the order of the adjusting bolts and now can;t get it right, when i adjust it right up the belt is still slack i must have the set up wrong on the adjuster. Help please.
Alternator fitting advice please-having trouble
Thanks, I have a 1995 3.0L I found the problem was that my alternator is different to the ususal one that Rough Trax supply, but they managed to get one to match from their supplier. Many thanks RossOriginally posted by BUSHWHACKER View PostCan't help you, I've no idea what model Surf you have.
