Hi guys, I've got two problems that I think are related due to their starting about the same time, but as they're random and intermittent I could well have two separate problems...
1: Every now and then I turn the key, get the dash lights on, wait for heater light to go out then turn the starter and all I get is a click and it doesn't turn over, if I try again it starts sometimes second go other times it has taken at least half a dozen turns before it turns over. Some times it can turn a little slow for a second then it picks up and fires, other times it fires straight away.
This can happen when warm and cold.
2: It has cut out while driving, it doesn't cough or splutter, the engine just stops dead as if you have turned the ignition off, but the lights on the dash come on.
If I stop and select park it fires up. Although one time I had to turn the key a couple of times as above until the starter turned.
I have looked under the bonnet and there doesn't appear to be any loose or broken wires or connections. I've not had chance to do any more as I pick my boys up from schools, they're too young to leave while I go messing about with the car, by the time their mum gets home it's too dark to see anything. I'll try and get a look this weekend but I'm busy Sat am and Sunday pm so any help and or ideas to get me started would be much appreciated.
Thanks.
Thanks.
Shoogled!
