Rear Speakers Wont Work On Cd
    behind side panels in the back of your surf as far as i know
      PanelS - does that mean one for each side?
      Ali
      [SIZE=7][COLOR=YellowGreen][SIZE=5][FONT=Comic Sans MS]The difference between the men and the boys .................... the price of their toys ![/FONT][/SIZE][/COLOR][/SIZE]
        not sure on that one never had mine off
          Yeah, there is one for each speaker.
            ive not attemted to remove side panels yet as ive had no need.
              So you said the first time. Getting your post count up again?
                look whos talking LOL
                  Ahh... I have had this problem too!!!! for the past ten months.
                  Sometimes the rear speakers worked with a CD and sometimes not... very frustrating.
                  I also noticed the rear speakers only came to life when the aerial was up but have never found out how to keep the aerial up when inserting a CD.
                  Having read this thread and now see there are amps in the back the problem is probably to do with the electric aerial and the amp positive feed, as the aerial goes down when switching to CD the power is being cut off to the built in amp for the rear speakers.
                  So how do you get around that??????
                  Ian
                  One day my paranoia will go away!
                  • #24
                    This may or may not help!
                    • #25
                      you sure the rear speakers have an amp each? bit unusual to have 2 single channel amps and not 1 2 way... i'd imagine them more likely to be crossovers? to split the high and low frequency signals....
                      the aerial will stay up with TA on as the radio is "scanning" for the signal to signify a traffic report.
                      • #26
                        They are in mine mate. One in each speaker pod.
                        • #27
                          that's just the japs being wierd again!...
                          i always thought that's why the speakers were 2 ohm... because they were components running through crossovers. could be active crossovers?
                          of course mine is completely different so i can't say cos i've nener seen the 2nd gen ones... so i'll just keep quiet! hehehe!!
                          • #28
                            This is them:
                            Rubblebags (Geoff).
