is 690cca enough?
  • is 690cca enough?
    Well the laguna has died on me. The water pump fell apart, stalled the cam belt and broke the valves. So I've had a look at the battery and it's rated at 690cca, would this be enough to start my surf? Considering it's been stood for two years.
    Hold my beer and watch this
    That is what most American muscle cars use so should be good for the job !!
    Only one way to find out !!
    Good luck
    Everywhere I go .... Im there
      I would say it may help certainly not the right battery, and you should have 2 on the surf. I have 1600 cca
      well, that was a bad idea!
        Yes.
        Even the diesel ones?
        Not all Surfs left the factory with two batteries.
          Cool well I'll give it a try and see what happens
            Hmm didnt know that, is that where the winter pack confusion comes from then
