Well the laguna has died on me. The water pump fell apart, stalled the cam belt and broke the valves. So I've had a look at the battery and it's rated at 690cca, would this be enough to start my surf? Considering it's been stood for two years.
is 690cca enough?
Yes.Originally posted by captain_chaos View PostWell the laguna has died on me. The water pump fell apart, stalled the cam belt and broke the valves. So I've had a look at the battery and it's rated at 690cca, would this be enough to start my surf? Considering it's been stood for two years.
Even the diesel ones?Originally posted by MIleshighhopes View PostThat is what most American muscle cars use
Not all Surfs left the factory with two batteries.Originally posted by muddle View PostI would say it may help certainly not the right battery, and you should have 2 on the surf. I have 1600 cca
