Hello Surf owners! I am new on this forum and have no surf but a 96 4runner with a kz-te engine out of a KZN130.
The engine came with the computer and the harness to the engine but the third connector was cut. I found a wiring diagram which worked more or less. The truck is running and drivres ok, but i still have wires i don't know where to hook up. The wiring diagram has only the essentials. I have another picture with the ECU and all the connections functions, but no clue what some of them means and where should be connected.
What i am looking for a whole wiring diagram for the whole car.
(It is not electrical, but mention here i have the famous overheat problem.I might have a partial block in the radiator, but new one on the way so 'll see it soon. However i think the overheat might comes from other issues. My idea is since not everything hooked up properly the ecu isn't controlling the proper way fuel flow, or something. I think my turbo is not working properly either i can't here that whistle that I hear in different youtube videos.(Boost pressure will be measured tomorrow)
Thanks for all the help.
