hey all im trying to change my light bulbs,,hahaha you say,, basically i know ive gotta take the lights out but my grill is stuck fast how the hell does it come of? the indicators seam to be attached to it !are they??? please help as the dark sucks lol also any pics would be a great help also we have loads of snow here and i wanna take pics of the truck in the snow
hmmm this is a silly question
Hi there,which bulbs are you trying to change, sidelights if
you take out the 2x screws from the housing then you have to
gently pull the indicators/side light assy out from the side.
there are locating lugs that go into the bodywork.
once off you can then take the grill off,I'm not sure but can
you not get to the headlight bulbs out from the back without
the need to take off the grill?
Rainging in Reading what a good day off? no snow to play with
Regards Chris
GOT NO COWBOYS HERE?
Take the indicators out as has been mentioned they pull forwards after the 2 screws are removed, then unclip all the little clips with a flat screwdriver, pushing down on the little tabs from the front though the grill. They are tricky and break easy so go carefull.
Or you could take the batterys and washer bottle out and get the bulbs from behind4x4toys.co.uk - Keeping you on and off the road...
