Can any of you kind souls please check something on your Surf for me please?
I got in my Surf this morning to go to work, turn the ignition, just got the dreaded 'click'. In my experience, this sort of thing is usually caused by either a sticking starter, or there isn't enough juice in the batteries to turn it.
At this point I noticed that the battery indicator was only about half way up the dial, ie appx 9v. After a few more clicks it fired no problem. When driving and after I'd got to work, the indicator is 3/4 the way up the dial, appx 13v.
This leads me to believe a battery problem, but what confuses me is that if there isn't enough juice on the first attempt to turn it over, why would there be on the fifth attempt?
If anyone can check their dial before firing it up after you've had it parked for a while I'd appreciate knowing how your dials read.
Thanks.
Thanks.
