Hi all,
We've managed to replace the fuel pump, but when we pulled the old pump out, we managed to yank a cable out of one of the sensors, namely a small plug right behind the injector pump on the passenger side of the engine bay. It's a black plug with two wires - red and white.
Questions:
1) which way around do the wires go (with the clip at the top of the plug)?
2) anyone know what this connector is for?
3) if so, could it explain the engine running REALLY rough and not actually recognising it's running? We tried starting it up and the glow plug timer beeper didn't switch off when it fired.
Cheers,
Gargravarr
Questions:
Cheers,
Gargravarr
