Hi all. Ive just moved to Italy with my Surf, and naturally ive started to use the aircon more than i used to in the UK. Ive noticed that it never really gets that cold, and usually takes about 15 minutes to get to its coldest temperature wether on recirc or not.
It was recharged around 9000 miles ago so i dont think that is the problem. Also, possibly unconected, ive noticed that when the air is turned off, there seems to be quite warm air coming through the vents, much warmer than the air temp outside and this is with the temp set to the coldest.
There seems to be no obvious leaks anywhere.
Any ideas anyone?
Any ideas anyone?
