The rear window on my Surf only closes with the key, it won't open. It goes up and down just fine from the switch.
I've opened the back door up, and checked all the connections, and used a multimeter to confirm that the contacts in the key mechanism work fine.
I can only guess that it might be a broken wire somewhere, but i'm having a bugger of a time tracing the wiring. The wires from the key switch run along the top of the door, then down the right hand side, where they appear to join into a bigger wiring bundle. I think they then emerge in a large 6 way connector attached to the lower right side of the door, but I'm not sure.
Does anyone know for sure where the wires emerge, and how I might go about fixing this?
