Is it possible to recalibrate or modify a tacho that reads 4 cylinder to read for a 8 cylinder ? Basiclly a 8 cylinder engine has been fitted into a 4 cylinder vehicle and the tacho is now way out . Can a resistor or anything be fitted to reduce the reading ? Dont want to change dash , need to keep it original .
Anyone an electronics guru ?
Seems like a resistor/potentiometer can be used in place of the ballast resistor on the gauge, the guy who does the lions share of MR2 engine transplants in the UK modifies them (www.woodsport.org).
Alternatively there are these little boxes of gadgetry:
http://www.dakotadigital.com/pdf/sgi-8d.pdf
Thanks , links look helpful .Originally posted by Chris W View PostSeems like a resistor/potentiometer can be used in place of the ballast resistor on the gauge, the guy who does the lions share of MR2 engine transplants in the UK modifies them (www.woodsport.org).
http://www.dakotadigital.com/pdf/sgi-8d.pdfRick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
