When starting the truck from cold there is a tonne of white smoke out from the exhaust, but when starting from hot its fine.
I have already checked the plugs for continuity and all four are also fine.
All four plugs are getting the 11 volts or so when starting and after a few seconds when the little light on the dash goes out my volt meter reads 0 volts on the plugs.
now im sure the second glow plug relay is working because ive checked that for continuity too, is there anything else between the second plug relay and the plugs them selves that controls the voltage drop to 6 volts or whatever it suppose to drop to?
Also i remember from my last Surf before it died there was a beep from behind the dash if you leave the key in the ignition too long before turning the engine over, i dont get that anymore in this one.
It has become harder to start the car as i have to turn the key 3-4 times to get some heat into the engine before i turn it over and even then its still lumpy until its warmed up.
I hope ive explained it alright.
Any help you guys have is most appreciated
Thanks Jason
Thanks Jason
