hi all, further to my post about 5 postings before this, rear window wont go up or down // this is what i have done to this time, removed the carpeted cover from the rear, and the plastic dust cover sprayel all around the runners cogs etc with wd40, however we can hear the motor going when the rocker switch is set either for up or down, but the glass will not go up or down
it has to be helped on its way by hand, my daughters partner who is a car mechanic is of the believe that that the problem is probably the motor, its tired and worn, it will run but does not have the umph to push the glass up or down, any thoughts, also i seem to have read somewhere on the forums that a replacement motor can be got out of another toyota, any ideas please, for the time being loading and unloading will have to be done via the rear passenger goors not ideal but hey it is 18 yrs old,
