Right.. Window goes down, but not up...
I have done all the usual checks, and my checks have been checked too..
http://www.toyotasurf.asn.au/techsit...te%20elecs.JPG
Been checking with this diagram. All the interlocks are doing what they are supposed to, tested at the switch, and at the relay box. I have tried a spare relay box. Relays are clicking for up and down when the key in the door is used, but only on down when the cab switch is used. On both boxes.
Does anyone have a wiring diagram for inside the relay box?
Also the diagram shows a Diode on pin 17, whats that do?
In short, Help!!
In short, Help!!
