I am installing a field monitor from a breaker and as my surf did not have one, I have followed the thread found at yotatech. Everything went well apart from the speed sensor cable splice.
According to the guys at yotatech, I need to splice into this cable on the ABS ECU:
However, there is no wire in that position on the plug on mine!
Does anyone know which is the correct wire I am looking for?
Either that or perhaps someone has the correct version of the service manual?
Thanks!
Thanks!
