My 94 SSRX has an immobiliser that ideally I'd like to remove. I popped into my local auto-elec specialists to see if it was possible, they were far from helpful. I suspect they think I'd nicked the car as it was still on English plates and I'm in Guernsey (and I was wearing my hood up
). Anyway, they said, and I quote...
"It's impossible, it'll cost you about £600."
At which point due to the contradiction in that one sentence I instantly thought the bloke I was chatting too was clearly a moron (and he owned the place). Unfortunately it's the only auto-elec specialist on the island.
Anyway to cut a long story short, does anyone know if Jap import 94 Surf SSRX's came with factory fitted immobilisers or is the one on my car likely to be an after market add-on?
Does anyone have the relevant wiring diagrams if they did?
...and is the immobiliser programmed into the main ECU?
Can it actually be removed without buying a new ECU?
I'm no electrician but I'm sure it must be possible to remove it somehow, any advice would be much appreciated. Thanks.
). Anyway, they said, and I quote..."It's impossible, it'll cost you about £600."
