I've a few questions about wiring up my stuff in the truck, what i have (or will have) is a sterio head unit in the roof console and a touch screen tv in the double din slot, what i need advice on is wiring the speakers (i'm not useing the trucks original loom, i'm running new speaker cable all round) how do i run the speaker wire from two units? the head and the tv, should i fit a load of small switches in the speaker wires for switching from one unit to the other or can i just double up the connections,
also i'm unclear on how to actually wire the speaker wires, you have eight wires, 2 per speaker pos and neg each, how do they connect to the amp "speaker output" this has 4 connections, marked + left and + right with "bridged written under that,
if someone could reccomend a wiring diagram for idots that would be great,
regarding the amp, the one i bought cheap has a missing metal part from the "rca" phono type sockets, so 1, is this repaiable and 2, do i actually need these to run the amp?
finally still on the amp i think theres a wire that goes from the head unit to the center connection on the power imput , there is a wire already marked "amp" on the tv unit but from what i can see the Blaupunkt unit requires you to buy a "preamp/sub/center-out cable, found the item on their web-site and it 20 odd naffin quid, from the diag of it it has 6 phono jacks, a wire marked +12v amp, a wire marked BN and an unmarked wire, so do i have to get this or can i just connect a lead from the terminal shown to the amp (rem) does this need a switch?
if anyone can help or would be willing to draw a diag i'll pay ya or do your heater leds for nowt, whatever!!
this thing is doing my nut,
the last pic is the inside of the thing showing the rca phono jacks wotnames
No good for those that like crossing rivers though!
finally getting it all done
