Hilux Surf SSR-G Speedo problem
  • Hilux Surf SSR-G Speedo problem
    I have an intermitant speedo which looks like an electrical connection problem. However I cannot find a wiring diagran that shows the connection.
    Can anyone help or advise please ? Clive.
    Is it a 2nd or a 3rd gen?
    '96 Toyota Hilux Surf SSR-G - RIP
      Toyota Surf speedo problem
      Thank you IanB2 for your reply. Being a novice about surfs I do not understand the question you ask or where to find the data to answer it .
        Try pics here.
          What year is your truck? '96-'02 is considered 3rd gen, earlier trucks are 1st or 2nd gens, and the wiring is different for each.
            Hilux Surf speedo problem
            Thanks again. My Surf is a 5 seater estate, not a pick up. It is an import from Japan first registered in England in !993. I have no idea of it's year of manufacture in Japan. Clive
              Look at the link - look at the pics. Which does yours look like? Simples.
                Does yours have a LIFT UP tailgate or a DROP DOWN tailgate. Answer that correctly and we will tell you which generation Surf you have
                Сви можемо
                  Log book, VIN number ? Got to be KZN 130 surely
                    How in the world do you insure a vehicle without knowing what year it is?
                      More about my speedo
                      Thanks all for your input. Regarding insurance my uk registration certificate states ' Imported vehicle- was registered/used overseas. declared manufactured 1993' This was the date used for insurance. If this is accurate then it must be 2nd. generation
                        Yes, 1993 would be a 2nd gen. 3rd gens start from late 1996.
                        The manufacture date will be on the seatbelt label .
                          My 3rd gen was built in Feb. '96, maybe you meant late '95?
                            Over here I have seen several '96 2nd gens. I've never seen a '95 3rd gen.
                            Does your 3rd gen have multi-mode 4WD? (centre diff)
                              Yes it does, and a lift up tailgate. Weird.
