Heres a good one for all you nice people out there
Drivers door window,switch has four positions,two for up,two for down.
Press or pull the switch all the way and the window will go up/down all the way in one swift action,but the other two positions on the switch allow you to open or close the window however much you want to,I.E. a bit at a time.
Mine will go down a bit at a time,but the up option doesnt seem to work as it should,I swapped the switches over with a complete spare set I have, no change.
Could it be a relay or something I havent thought about,or does my model,ssr x 3ltd not have this option as standard,
Any help/advice gratefully recieved,Thanks,Alan
