Well the temperature reading is spot on but the issue i have is with the built in volt metre. With ignition lights on it reads 12.5ish volts & once runniing it reads 13.4 - 13.9ish, now the problem comes when you rev the engine or drive "at any speed" the voltage drops to around 9.0 volts & stays there unless i turn the head lights on + full beam then it goes up again but drops off after a few seconds.
WTF is going on, ive checked & double checked the wiring is correct so can anyone shed any light on this please, hoping its something simple but knowing my luck...........
Cheers si.
Cheers si.
