Rear door panel
  • Rear door panel
    My ofside rear window as broken & I can,t remove the panel to get at the motor. It,s the door opening handle that appears to be stopping it. Any help welcome.
    door panel
    If everything else is loose , unscrew the door release & ease out gently.
    Its held from behind by a rod connected to the rest of the mechanism. You should be able to pop it out (may need to release a sm clip on the rod.After that disconnect anything you missed and off it comes
    Geoff
      Had the same problem with my fronts. The Door handle slides forward before it comes out. Remove the screw then press firmly on the rear of the handle surround moulding. You should then feel a click and then you can pull it forward. Once pulled forward, with a small screwdriver rotate the small clip holding the actuator rod and pull the rod out of the handle.
      The Handle will now come off.
