My ofside rear window as broken & I can,t remove the panel to get at the motor. It,s the door opening handle that appears to be stopping it. Any help welcome.
Rear door panel
Had the same problem with my fronts. The Door handle slides forward before it comes out. Remove the screw then press firmly on the rear of the handle surround moulding. You should then feel a click and then you can pull it forward. Once pulled forward, with a small screwdriver rotate the small clip holding the actuator rod and pull the rod out of the handle.Originally posted by YaskerMy ofside rear window as broken & I can,t remove the panel to get at the motor. It,s the door opening handle that appears to be stopping it. Any help welcome.
The Handle will now come off.
