Morning all,
Just easing myself in to the wonderful world of Surf ownership and seem to have one of the recurring problems:
Soon after purchasing the truck i got the click on starting, then nothing. Decided to get the starter motor replaced instead of refurbing contacts.
All was well for a couple of weeks, but since the cold weather it never has enough charge to start up - so i just get a click the same way as i did prior to replacing start motor. When i hook up my jump start box it fires up straight away.
Tested both batteries with multimeter - about 12.3 when engine off and 13.8 when idling with blower and headlights on full. Interestingly when i switch the rear demister on as well the charge drops below 13.
So jump start this morning then a 20 minute A road journey to work. Park up, let the engine idle for a minute with all the electrics switched off. Turn engine off, then try to turn on again. Nothing but a click!
Are the batteries funked or do my problems run deeper than this?
Thanks for any suggestions, so glad i found this forum - the advice really is first class.
cheers
cheers
