hi all have just found the fault with my surf not starting in the mornings when the weather gets cold (for the past three years and three new batteries later grrrrrr)  ive read so many post from people with a similar problem and the answer for mine was so simple are you ready? ###### BATTERY TERMINALS!!!!  the originals have a stupid piece of black plastic under and between the terminal clamps and i imagine the clamps must stretch a bit over the years and when the n/s battery needs most help from the o/s one ie cold mornings it wasnt making a good enough contact so i cut the old terminals off fitted nice shiney new ones with big fat 13mm nuts and bolts and hey presto has started every morning this week! yaaaaaaaaaayyyyy
 i hope this at least helps some of you.
