Auto Aerial Problem
  • Auto Aerial Problem
    3rd Generation 1997 P Reg. Surf
    The auto aerial goes up when the radio is turned on as expected and comes down when turned off as expected, but when listening to a CD etc. the aerial remains in the up position - this occurs with both my old and my new radio, and I have been assured it should go down when listening to a CD etc.
    I have the wiring diagram in front of me, which shows two wires (B-Y and P-B) going to the back of the radio. I have never had a standard radio in the car so don't know if both of these should go to the blue wire from the back of the radio, as they are now (joined by a bullet connector to the Blue from the radio).
    Can anyone help please - maybe it is simply a case of splitting these two wires, but to what I don't know!
    Thanks
    I have the original Radio/CD/Tape/TV unit in my 2001 3rd gen. If I select CD before switching the unit on, the aerial stays down.
    Hope that helps.
      Hmmm
      That would suggest that the two wires are meant to be independent of each other, but I still have no idea how to wire it up properly then!
        I just fit a new Sony unit to mine & that only goes up with the radio on & stays down on cd & when on the phone "Bluetooth".
        My old alpine stayed up all the time regardless & both units are wired exactly the same.
          Do you remember which wire(s) you attached to the blue wire from the radio - was it one wire or are there two joined together?
            According to this the two antenna wires are joined....
            http://www.installdr.com/Harnesses/Toyota-Wiring.asp
              It was all factory plugs with no joining of anything.
