I have had the clocks out to replace blown bulbs and when I started her back up the warning laps came on the dash battery, AT temp etc and she isn’t charging.
I have checked battery terminals, earths and checked voltage on alternator terminal and it isn’t putting anything out just reads battery voltage.
The battery light is on with the ignition and doesn’t illuminate when you remove the connector from the back of the alternator (as it should)
Have I disturbed something behind the dash? or is it just coincidence the alternator failed the very next time I started it up?
What is the ALT fuse? it looks ok but haven’t dug it out to check.
Any thoughts before I pull the alternator off??
Thanks
Thanks
