Hello
Having finally managed to get my 2.4 td to the garage to check if the starting problem was the glowplugs, i've just been told one of the plugs has broken off and another seems to be going the same way?
I have a choice of trying to start it with 2 glow plugs and the possibility that the bit of broken plug may foul up the engine or pay several hundred pounds to have the head taken off and to get the broken bit out that way?
I can only go for the first option unfortunately and just wondered if anyone had heard of this before and knew of the outcome?
He also said the only time this had happened before was with a Hi Lux so it may be something they are possibly prone to?
Any input gratefully received......... thanks!
Is this an electrical prob? sorry-not sure!
