In the morning, rear window not going down.
Sometimes when the key is turned the rear wiper starts instead!
Also, if you turn the wiper on intermittment for the rear window it keeps going, flicking off the glass onto the rest position and back again. Often if you then drive the truck and leave it sitting for a few mins everything returns to normal. Should I be looking for a loose wire or is something more serious up?
The only way I currently get round this is by leaving the back window open very slightly.
Any suggestions appreciated
