Hi, I have a 1993 generation 2, 3.0 turbo diesel Surf.
Up until I sent the Surf off to have a towbar fitted a couple of days ago, the rear window worked perfectly via both the key switch and the centre console switch. Now the key switch will not lower the window.
After I told the guy who fitted the towbar about this problem, I didn't like his response and decided that I didn't want him to touch my Surf again and will try to fix this myself [gulp].
The centre console switch still works fine and will raise and lower the window, so I'm assuming that my relays are OK?
I have checked that the window lock switch is set to unlocked, the rear wiper is properly seated in its home position and I have sprayed copious amounts of WD40 in to the key switch - to no avail. I don't get a 'Back Door' warning either.
The only thing I can think of is that the key switch has developed a fault or the wires from the key switch to the relays have.
Any ideas?
Thanks,
Jerry.
Any ideas?
Thanks,
Jerry.
