hi all
does anybody know where abouts the pressure switch and relay are for the air con system its a 3.0 lt diesel 2 gen
ive fitted a new pump and regassed the system but the pump does not energize, when you supply a feed to the front clutch it runs ok , so thinking must be a pressure switch fault or a relay , cannot find a pressure switch anywhere or even the relay!
many thanks
many thanks
