Having probs with windows and central locking at the moment, well they just dont work. After a lot of pain, due to bad back, managed to locate 30 amp fuse in drivers footwell. Cant figure out how to remove it to check if its blown, eyes like back dont work too well. Tried to grip pink plastic with long nose plyers but only manged to pull bit of plastic off. Is there anything else that this fuse protects so I can try to eliminate it from further investigation, and if not how the hell do I get it out. If it helps I can also say that the tailgate window no longer works from the switch on the consol but still works on the key. I belive that a common problem is the wires breaking where they pass between the body and the door. Can anyone tell me how to check there condition.
Cheers Spoggle
					Cheers Spoggle
