im tryin to get the starter motor out its been playin up for a while and finaly given up,found a thread bout removing it but no pics,ive got the bottom nut n bolt out, power supply to the bottom left off,but can a hell find the top nut,and does the top cables come apart from each other or pop out of motor its self,got refurb kit orderd,so need it out asap as i need the motor for work
starter motor
Tada
http://www.toyotasurf.asn.au/techsite/starter.htm ........... and once its out http://www.monthofsaturdays.net/surf...r_Motor_Refurb ..... that should about do it
Last edited by wiggy; 29 July 2010, 13:01.The sh$t gets deeper ...but still swimming
http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=26011
Sorry think its about 4 paragraphs down..if its the same thing..havent done this myself yet but been reading up on it for a bit.
the easy way of getting to the top nut is from the front of the engine, you need about 2ft of extension poles with a socket on the end and then its actually really easy to un do.
My haynes manual says" disconnect the leads from the starter, there is one clip connection and one terminal held by a nut and washer"
not sure I remember that but thats what it says.
read this guys write up also:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtmlLast edited by truckarms; 30 July 2010, 12:23.
thanks for all the info,had another go this morning still no joy getin it off,just havnt got the tools to get the top nut off,rang auto electric place up said they would do it if i take it up but cant get it started tried tapping it with bar n hammer still nowt,tried garage up the road if they get there work done early they gonna send some one down to take it off,have to ringem back 3.30 if not its gonna be tuesday
another 2 days work lost
I used to sit there for ages trying to get it to start, hitting it will do nothing if the contacts are shot, you just keep trying until it manages to arc across the contacts and fire into life then just try to avoid turning it off, or you get stuck in petrol stations and get fed up with people who think they are clever telling you "You've got a dead battery mate" and you reply " No I havn't it's the starter motor contacts" and they say " I know a dead battery when I hear one mate" and you reply "It's not a dead battery and I'm not your mate!" then it fire's up and you drive over their stupid little car and off into the sunset until you inevitably have to stop again somewhere!
Rant
When I did mine I was able to leave it in gear (I have a manual) and rock the truck to spin the starter a bit, that would get it to start every time as it was only in one position where the starter could not start.
I've done the contact replacement now, that was the easy bit!
Mine came out through the top of the engine but I have a 2.4 so I'm not sure about yours.
If you have an auto I have no idea what you can do, sorry.
Ray.I've got a plan and it's as hot as my pants!
