This light appears towards the right of the dash (2nd gen 3l surf) - it looks like a car with 2 or 3 wavy lines behind it..
It appears intermittently - some days not at all, some days on all the time, other times flickers on a bit and seems to come on with an increase in engine revs, then off when I take my foot off the gas... then a while later it disappears.
I wondered if it was some kind of emissions sensor?
The truck was serviced in January, oil change, new air filter. it was MOT'd about a month ago and passed the MOT and emission test no problem.
Coolant was done a few weeks back, new thermostat, flushed and filled...
Only current engine niggle is a small oil leak, possibly from the rocker cover.
I'm using normal diesel (it says at the pump it's up 7% biodiesel) with no added veg oil or anything.
I don't have the owners manual, and I've looked for a pdf one that showed me this light but no luck so far...
Hope someone can help!
