i've bought some 'super bright' replacement headlight bulbs, and was going to fit them today, but it seems ya have to take have the engine out? do you have to remove the battery's etc to get at the bulbs, or is there an easy way?
Is There An Easy Way To Change Headlight Bulbs?
thats if hes got the winter pack lolOriginally posted by BUSHWHACKER View PostJust disconnect one battery, unbolt and move plastic tank to the side and replace bulb.
Re-fit tank and battery and repeat on the other side.
The batteries are wired in parallel so as long as you keep one of them connected, the alarm/immob won't be affected.
hahaha, you lot a frickin nuts!
yes, indeed i have the winter pack, and yes, yes, my bad, i will be sorting my lights out this wkend, and i will move each BATTERY at a time (thankyou Bushwacker), so then i will not have both BATTERIES disconnected at the same time!
wh( . )( . )p wh( . )( . )p
www.vidamusic.co.uk
All KZN130, and all EFI LN130's have two batts regardless.Originally posted by VidaMusic View Posthahaha, you lot a frickin nuts!
The mythical 'winter pack' is fuel heater, heated mirrors and seats, and KiteSurf Phils truck was the only one i've ever heard of with it.4x4toys.co.uk - Keeping you on and off the road...
