i have just changed the radio in my 2.4 1992 surf after putting every thing back together every thing is dead that work through the ignition ive checked all the fuses and for disconected wires ect cant find any thing wrong every thing that runs direct from the battery is fine just no ignition power help!
dead surf
Originally posted by cuz 62i have just changed the radio in my 2.4 1992 surf after putting every thing back together every thing is dead that work through the ignition ive checked all the fuses and for disconected wires ect cant find any thing wrong every thing that runs direct from the battery is fine just no ignition power help!
check the batteries, terminals etc.Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
I'd check the fuses again. The ignition stuff including the radio is fed from a 50amp fuse. I think it is in the engine bay fusebox rather than the one in the drivers footwell.
Rich.If life's an uphill struggle then downhill from now on can't be that bad?!
