I'm having a bit of trouble getting my rear interior light to work when i open the back door on my Gen 3. The light comes on when you switch it on inside. & the light on the dash comes on if the spare wheel carrier is not closed properly. But the light has the word 'door' written on it & i figured it should come on when you remove the wheel carrier???
If it is a switch problem in the door is it easy to get the rear trim panel off only the switch looks like its riveted into the door!
Will.
Will.
 or whatever lets people get comments in context.
