Hi I'd be grateful for for some help (spent ages searching for info but can't find what I need).
My rear window suddenly stopped working a couple of weeks ago. It is stuck in the up position but unfortunately my dog box is in the boot(luckily the dogs weren't in it!) All I get when I try switch/key is a click from solenoid, I have checked the window lock button is not down and the rear wiper is properly parked.
After a huge struggle I managed to squirm behind dog box and remove the trim and metal panel from rear door. I checked voltage on connector to motor while switch was pressed and got 12v so fairly confident the motor has packed up. My problem is cant see bolts fixing motor to regulator, I think I can feel them at back but they feel very rusty.
My question is: would I be better to remove the whole mechanism and if so how do i do it?
Any tips/pictures would be much appreciated. Thanks
