The little bulb that illuminates the auto gear shift on my 1993 surf is bust and I want to replace it, but so far I've only managed to get in behind it - to the bulb holder. The cover with the gear markings on it doesn't want to lift off - there's a little red button at the end of it that is possibly preyenting it shifting? Anyone come across this before? Any tips for getting to the bulb? What is the bulb? Would make life easier if I could see what gear I was in!
Awkward bulb!
you know i didnt even know that was supposed to illuminate
ive lifted the cover with the markings half way off in the past, usually whilst waiting for the missus, but i too noticed it doesnt appear to lift off behind the red button. i can get it to lift over the button but there is still a tabn that secures it behind that again.
i reckon the tab will break if pulled to hard so i figure the cover needs to be removed whilst in a more horizontal position.
ill have a look at mine again later after ive rescued my truck and will report back if no one else has.
I lifted the plastic centre console that houses the gear levers. The gear indicator cover lifts at the peas end, but not at the forward end, so not enough space to get at the bulb. I undid the black plastic housing at the base of the auto shift to get in underneath the bulb and got to its holder but couldn't shift it and stopped because I didn't want to break it. At a bit of a loss how to get in above the bulb when the cover refuses to shift at one end, and don't want to snap it... What's the little red button for anyway??Originally posted by BUSHWHACKER View PostThe plastic surround (the section that holds the ECT button) and the screw that just under the short transfer lever knob needs to be removed to gain access to the bulb holder.. The bulb is a small capless type in a holder on the driver's side of the lever, that you twist to get out.
Someone did a small write up on here somewhere, when we both done ours ... Try this Guys
http://www.hiluxsurf.co.uk/forums/sh...t+illumination
There's always a Payback .. Cos ya don't know where n ya never know when !!Last edited by Diezel Weazel; 8 January 2010, 18:04.Buncefield Burner
As vince said, that cover doesn't come off, the lamp is accessed from below it. It will come out.Originally posted by BigYin View PostI lifted the plastic centre console that houses the gear levers. The gear indicator cover lifts at the peas end, but not at the forward end, so not enough space to get at the bulb. I undid the black plastic housing at the base of the auto shift to get in underneath the bulb and got to its holder but couldn't shift it and stopped because I didn't want to break it. At a bit of a loss how to get in above the bulb when the cover refuses to shift at one end, and don't want to snap it... What's the little red button for anyway??
By the way, even if you do get that plastic cover off, you still can't see the lamp.
Where in Central Scotland are you?Do you know that, with a 50 character limit, it's
I did mine earlier this week, it's not too bad - loosen off the (centre consol)cowling so you can lift it, but not the black gear lever part - the bulb holder is visable underneath, just twist it about 90 degrees using finger tips, pull old bulb out and pop new one in - getting the holder back in is very fiddly but do-able.“Do or do not... there is no try.”
Thanks everyone - much appreciated - I also really appreciate the help with 'what does the little red button do'
- totally new to these motors as you can maybe tell!!
Where in Central Scotland am I? Just outside Falkirk - I was directed here by Kerrsurf (Alan) who will be helping me with the majority of the work on the Surf - but I don't want to expect him to do everything.....
Sorted! It was the advice from New Surfer that clinched it - rotate the bulb holder 90 degrees from beneath - I'd got to the bulb holder but wasn't convinced it would come out and didn't want to risk breaking it. So, done - put in a 12v 1.2w push-fit bulb I had and voila - it works!!
I broke the tab at the rear end of the gear selector cover when I initially thought I could get to the bulb from above - so since that doesn't need to lift for future bulb changes it's been araldited down.
Thanks again for your help!
Kerrsurf is more than welcome to come and do all my maintainance (I'm only about 500 miles south of you) lolOriginally posted by BigYin View PostWhere in Central Scotland am I? Just outside Falkirk - I was directed here by Kerrsurf (Alan) who will be helping me with the majority of the work on the Surf - but I don't want to expect him to do everything.....
Glad I could help, so many people have helped me on here
