I need some help in obtaining a couple of relays for my 4wd comp control.
The relays are situated in a black box at the base of the centre console.
The relays are a 5 pin design & on the top have
" OMRON G8S-114P-02T
12VDC
20Z9D6 "
I think these relays are the same or very similar to the ones that control the tailgate rear window.
I had these replaced a while ago, but the shop that did them has closed down.
I can't face ripping the rear panel out to check the window relays but I think the omron relay may be dis-continued & replaced with an alternative.
I can find someone to do the work if I can source the parts.
I've searched on the net but the technical info is too complex for me to cross-reference a new relay.
Thanks
12VDC
20Z9D6 "
Thanks
