Hi Guys,
I've been trying to fix my load space light (works in on position, just not on door open) with no luck yet - but i'm trying to look at it from a different way:
The buzzer and whatever stops the window from opening when the tail gate is down doesn't work, with the tailgate horizontal i can put the window up (i know it's a bad idea)
This works from both the switch and the key - what controls this? I'm guessing it's the same switch that does the light?
On the left catch/switch if i test for continuity i get permanent continuity regardless of catch position, on the right no continuity regardless of catch position!
At the light itself I have 3 wires
1. earth (white,black) working
2. live from fuse box (Blue,yellow) (showing 12v)
3. Switch wire (Green,blue) (showing 12v regardless of catch positions)
PLEASE HELP MY BRAIN ACHES!! what should these switches be doing?
