Just checked and the left hand tailgate sensor is a bit over-sensitive, I've disconnected it and it seems to be working fine on the one sensor.
I connected the motor up and all is back to normal, window goes up and down fine. I was thinking, it has to be either the back door key switch or the relay itself as they are the only parts of the system that are powered with the ignition off.
Thanks again for all the swift help you gave me today, what a great forum!
Its about a month old, the older one is Japanese so god knows how old it is. I think I'll get away with a battery age gap of 1 month.
