Hi,
I've tried searching but can't find the answer!
Where is the switch that operates the light in the boot?
I've just replaced the Tailgate window motor, regulator (ebay) and Window Channels (Roughtrax - channels were a nervous Job, I was terrified of braking the glass!)
On the regulator there are 2 switches - one is connected to the boot lock and warning light on dashboard (which didn't work before)
The other switch is moved by the regulator - is this the light switch? Or is it more likely to be a broken wire?
The window is now working perfectly - but it's annoying that the light has to be switched on manualy (bulb works!), because I then forget to turn it off!
Thanks for any help.
