Hi,
i need a little advice, i have a 3.0l turbo diesel, 1994, kzn130 surf.
i have bullbars and want to put on a pair of spot lights. i have hella comet 500, but may upgrade them to hella rallye 1000 or 2000.
i want them to be activated on the high beam circuit, i do not want a seperate switch.
i have done a little research, but would like a little confirmation.
i was thinking the best way would be to give the spot lights their own power circuit with fuse direct from battery, and use a relay activated from the high beam circuit to activate the spot lights. I figured this was better then just connecting them directly to the highbeam circuit
assuming this is correct i have a couple of question:
- what size/type fuse for power circuit? what size/type relay?
- just one power circuit, one fuse and one relay for the spot lights? or 2 seperate circuits one for each spot light?
- how do i take feed from the high beam circuit, just literally connect a cable from either the right or left hand headlight?
-is it possible to take a feed from both the left and right highbeam circuits, so if one blows out, the other will activate the relay and thus the spot lights.
any other advice???
obviously if there is a much better way, please say?
thanks in advance
J
any other advice???
thanks in advance
J
